Switch Loop question.
Old 10-24-06, 05:27 PM
Bernard_01's Avatar
I moved and my books are packed in storage. I did not draw the diagram and should be punished. Here is my scenario.
.White and Black supply go to light fixture #1.
.From fixture #1 a White and Black go to Switch #1.
.From fixture #1 a White and Black go to Fixture #2.
.Finally from fixture #2 a White and Black got to Switch #2.
Please tell me how to wire this and I will also respectfully accept any punishment you ladies & gents impose.
Thanks so much.
-Dark in New hampshire.
Old 10-24-06, 05:37 PM
green jacket's Avatar
AT FIXTURE #1
connect black from feed, black to fixture #2, and white to SW1
connect black from SW1 to black of fixture
connect white from feed, fixture, and to fixture #2
connect all grounds, and be sure use a green grounding screw and pigtail if the box is metal
AT FIXTURE #2
black from fixture #1 to White to SW2
Black from SW2 to fixture black
white from fixture to white from feed.
HTH
gj
Old 10-24-06, 05:39 PM
Sorry, misread your post.
Old 10-24-06, 05:56 PM
Bernard_01's Avatar
thank you gj. i'll wire these two lights first thing in the morning.
-Bob
Old 10-26-06, 10:30 PM
We're assuming that you want switch #1 to control fixture #1, and switch #2 to control fixture #2. Post back if you had something else in mind.
Old 10-27-06, 04:57 AM
Bernard_01's Avatar
Hi John,
yes, that was my intention. The diagram worked perfectly . lights on!
-Bob
Old 10-28-06, 07:52 PM
Unless I'm mistaken, you're also supposed to mark the white wires that go to the switches as hot wires, by wrapping some black tape around them or something, no?
Cheers,
Sy
