applicances on extension cords
Old 11-03-06, 11:20 PM
Why is it with appliances they say you can never use extension cords with them. I have a wall unit air conditioner that uses 12.5 amps so a 14 guage extension wire should be o.k. CORRECT
Old 11-04-06, 04:08 AM
"Why is it with appliances they say you can never use extension cords with them. "
Because case studies have proven this to be one of the most leading causes of death from house fires in the USA.
Cords are not designed to be a perminant wireing method. They deteriorate over time, and get kicked arround, or stuffed under something, which causes them to wear out faster.
Old 11-04-06, 04:54 AM
Speedy Petey's Avatar
Also, aside from damage a real source of danger is the attachment caps. They are a real weak point.
I'm sure most of us have seen burned and melted plugs and caps on cords of heavy draw items such as A/C's, vacuums, etc.
