Low Voltage question
Old 11-04-06, 06:18 PM
On a circuit,I have a light switch and five receptacles.
Only one of them work the other 4 there is no power.I checked the first one with the three other with no power with a voltemeter and it gives me a hot to ground 110 volts and hot to neutral 70 volts. I'm asking myself what might be the problem....thinking if there would not be an open should give me zero volts.I also dicovered that I have aluminum wirings and I just changed 2 of these 4 outlet including the first one with power and the second with no power with normal copper receptacles. Can this maybe be the reason that I get like only 70 volts hot to netural wire??!!!
Thankyou for your responds
Old 11-04-06, 06:26 PM
You have an open neutral (white wire). This will most likely be at the last working or the first not working device.
You changed outlets. make sure the terminals are rated for use with al/cu wire.
Did they work before you replaced these?
Old 11-04-06, 06:33 PM
Yes they worked before.
And I installed probably standard receptacles for copper wireing. May this be the problem?
Old 11-04-06, 06:51 PM
Retrace your steps, You must have a bad connection.
You should be alright with the devices.
Old 11-05-06, 06:13 AM
Using the copper devices on aluminum wire will not cause you to get the false readings that you are getting. An open neutral between the first and second recepticle would.
The copper recepticles or aluminum wire does need to be replaced, as this is a fire hazzard. The connections where the dissimilar metals touch eachother are not safe.
Old 11-05-06, 07:38 AM
Just to be clear.. The devices must be rated for use with AL.
Some out there are rated for use with both.
Old 11-05-06, 11:15 AM
Sthrnamp's Avatar
As others have stated...the cu receps are not for use with AL wiring unless otherwise noted (on he recep) The reasoning is that the wire connections will break down as a result of a chemical reaction b/w the aluminum and the alloy in the receptacle screws.
As for the problem you are now facing. Is the switch a three way (as in does it turn on inmore than one location?) Secondly...how many wires are in the one recep that does work? Thirdly, did you replace the switch as well?
