halogen dimmer switch?
Old 11-04-06, 06:25 PM
Can I put a dimmer switch on a halogen light? I looked on Leviton site but could not find it to say if you could or couldn't.
Thanks,
Harlan.
Old 11-04-06, 06:28 PM
Yes, make sure the dimmer is rated for the correct wattage.
Old 11-04-06, 07:26 PM
Speedy Petey's Avatar
Halogen or not makes no difference. The voltage is what matters.
Is this low voltage halogen or 120v line voltage?
Old 11-05-06, 05:09 AM
Good catch Speedy,
If low voltage get the paper work. Some can be dimmed and some not. Some require magnetic dimmers and some electronic.
Old 11-06-06, 03:04 PM
Thanks for the information. I have not found my directions for it. Hopefully I will. These bulbs are on a track and did find that it said 12 volt.
Here is exactly what it says:
Use only Type 3 Lamp 50 watt max. 12v,
