Overhead Light ?
Old 11-07-06, 09:13 AM
Overhead Light ?
I currently have an overhead light in my dining room that plugs into a socket. I already have power to the box above it, is there a way to hardwire that light into that box? The light came with the outlet plug attached, can I just cut off the plug and wire the wires into the box?
Old 11-07-06, 09:23 AM
No. You most likely CANNOT cut off the plug and hardwire this light. The cord on the light is probably NOT rated to be run into a junction box or attached directly to traditional branch circuit wiring.
What you can do is to replace the existing light wiring with appropriate cable and connect this. However, this will likely void any UL or other testing agency rating of the light, and it certainly won;t look good.
Old 11-07-06, 09:50 AM
I didn't think so. Maybe I will just wire an outlet up there.
Thanks.
Old 11-07-06, 01:33 PM
Received 136 Votes on 122 Posts
You could put a receptacle in the box and plug the light in. They make octagon box covers that will hold a duplex receptacle. You could paint the cover to match the ceiling.
