New construction - closets
Old 11-10-06, 06:43 PM
I'm doing my own work - quality but not up-to-date with the code!
My question: Can I use "screw-in" flourescents in the closets in my bedrooms - or must I use commercial flourescent fixtures or recessed units in the clothes closets in each bedroom?
Thanks - what a great source of info!!
Old 11-10-06, 06:45 PM
Go with the flourescents. mount it over the door. No rec. allowed in closets.
Old 11-10-06, 06:55 PM
Sorry, but perhaps I didn't make myself clear enough. I've already placed round boxes in, figuring to install "screw-in" fixtures and use the "screw-in" flourescent bulbs.
Is that OK or do I need to use regular flourescent fixtures?
Thanks for the reply anyhow!
Old 11-10-06, 07:03 PM
Speedy Petey's Avatar
There are very specific rules as to placement of fixtures in closets. Fixtures with exposed lamps (bulbs) are not allowed. Even if you intend to use CFL's.
Recessed are allowed, but enclosed trims must be used. No exposed lamps.
I suggest you read this:
http://www.selfhelpandmore.com/homewiringusa/2002/maindwelling/closetwiring/index.htm
Old 11-10-06, 07:09 PM
rdn2113's Avatar
Read NEC Article 410.8 Luminaires (Fixtures) in Clothes Closets
Recessed lights are permitted in closets per 410.8(B) Luminaire (Fixture) Types Permitted: Listed luminaires (fixtures) of the following types shall be permitted to be installed in a closet:
(1) A surface-mounted or recessed incandescent luminaire (fixture) with a completely enclosed lamp.
(2) A surface-mounted or recessed fluorescent luminaire (fixture).
There are requirements for proximity of lights to clothes, walls, etc. so be sure to read the entire Article.
Best wishes.
Old 11-10-06, 07:10 PM
My mistake too. the flourescent needs a lense.
?: how about a caged light? Ya know, a glass globe and cage.
Never tried, never asked.
Ah! That's what I needed to know.
Thanks!
