Box extender exists?
Old 11-12-06, 08:10 AM
I am refinishing a garage. The previous electrical work (probably by a professional) is top quality instalation. The boxes very secure to studs...properly secure grounding, etc.
My question. I don't want to remove and rewire all the boxes, receptacles, switches, etc. to add a half inch of drywall. Is there such a thing as extenstions to put on an existing box and bring the receptacle and switches forward? Some added front to the metal box to add a half inch or so? I have enough 'extra' in the wires to do this.
If this isn't possible, any tips on removing wired boxes? The ones in the garage are well fastened and I tried to remove one and destroyed it in the process. What tool is used to remove the nail? My studs have hardened over the years and it's a struggle.
Thanks
Old 11-12-06, 08:23 AM
Yes there are several types,These are available At HD or LS'
Remember, the box can be, NO More than 1/4" behind the face of the finish. So you may not need them.
There should be pleanty of wire to do this.
Disconnect the power before removing the rec/sw.,You may not even need to disconnect the wires, Slip the extension over the device.You will however need some longer screws (6x32) for the devices, (8x32) for the junctions :4'squares and rounds for Ex.
Old 11-12-06, 08:57 AM
nap's Avatar
nap
nap is offline
New Member
since these are metal boxes, if they happen to be of the 4" square variety and there is no wall covering now, you can use plaster rings with either a 1 or 2 gang opening.
this should be a link to a single gang 5/8" plaster (or mud if you prefer) ring.
http://www.hubbellcatalog.com/raco/raco_datasheet.asp?PN=8768&FAM=RacoBoxes&P=325,1076,1594,116
Old 11-12-06, 09:19 AM
thanks! you've saved me a LOT of work. I don't mind doing electrical work but I do it at a tortoise pace to make sure I get it right. Your advice is much appreciated.
My father, a carpenter, used to advise that if you mess with plumbing and get it wrong, there is a lot of cussing. If you mess with electrical and get it wrong, you might not still be around to do the cussing.
