6/3 Romex, 50 Amp Breaker, Electric Range Install.???
Old 11-13-06, 12:03 PM
ewheatley's Avatar
Exclamation 6/3 Romex, 50 Amp Breaker, Electric Range Install.???
Gotta question for you guys. I am in the middle of a kitchen re-model, and one of things that I need to change is to run new cable for the electric range to directly below to the panel. I had a new panel installed a couple of weeks ago (an upgrade from 100 amp to 100 amp.)
I have a couple of questions about the best way to go about doing this.
1.) My electrician recommended 6/3 Romex, which I just purchased. It has 7 or 8 small wires rapped with protective coating to make up one wire. Is this the correct wire to use?
2.) Does it matter if I use a surface mount or recessed mount? Is one better/safer then the other?
2a.) If I choose to use a surface mount, does it mount to the stud behind the wall, or to the floor?
2b.) Say that I surface mount 8 inches from the floor, does the cable need to be covered?
3.) When I make the connection in the box, should I knock out one of the side or bottom slots, or go through the top where the other wires are coming in?
Any tips would be greatly appreciated.
thanks-
Eric
Old 11-13-06, 02:32 PM
Received 42 Votes on 40 Posts
6/3 is the correct wire. It should have an outer jacket with a black, red, white, and bare copper wire inside. The three insulated colored wires will be made from several strands of copper.
I prefer recessed when possible as some ranges have bumps in the frame which can keep the range from sliding all the way in if the surface mount receptacle is in the way. Safety-wise, either is legal. If you do choose recessed, use a 4-11/16" square steel box fastened to a stud with a 2 gang mudring. The big box stores usually carry this larger junction box, and the extra room is very nice when working with the fat wires.
The wall, but it can be at floor-level.
Yes.
Wherever there is adequte room to fit a 3/4" romex clamp. The top will look cleaner.
Old 11-13-06, 08:31 PM
> coating to make up one wire. Is this the correct wire to use?*
Correct.
No, Surface mount will give more flexability when the unit arrives.
Either.
No, Due to the fact it is behind the appliance. therefore out of harms way.
Old 11-13-06, 09:29 PM
lectriclee - Are you saying that he can have exposed Romex ? I did not see where this was a built in unit. If he has wall mount receptacle - I would think that the romex would need to be behind the wall or covered. Just asking ...
Old 11-13-06, 09:37 PM
Wink
Yes the romex can be "exposed". It will be behind the unit.
therefore not exposed to physical harm.
If it is not.. then yes you must protect it.
Leave some slack in the cable so it can go left-right-up or down.
Personaly, I dont care for box mounts for ranges, for the simple fact your locked in. If it aint just right..... You say very bad words and wind up relocating it.
Old 11-14-06, 05:51 AM
ewheatley's Avatar
Thanks for all of the helpful tips!
I measured against the range for space allocation and mounted the receptacle surface mount last night. I have not ran the cable to the box yet. That is on my "Honey do List" tonight!
