Non-Grounded GFI
Old 11-14-06, 03:47 AM
Non-Grounded GFI
Hello to all-
As always, this is an excellent forum (I visit it weekly to pick up pointers), and wish to thank all the pros who volunteer their time! I have a receptacle that is ungrounded and have a aquarium filter (in contact with water) that is plugged into this outlet. I am installing a GFCI receptacle in its place ( I will label it as non-grounded), and want to know what additional protection if any this will provide. Is this overkill? Will the GFCI still trip with current leakage?
As always-
Thanks much!
Ray
Old 11-14-06, 04:32 AM
A GFCI receptacle will work just fine with no ground. It is not concerned with the ground at all. It is only concerned with the difference (hopefully none) in the current between the hot and neutral wires.
However, the GFCI will NOT provide a ground. If you have some sort of device that needs a ground to function properly, then the only solution is a properly grounded receptacle.
Old 11-14-06, 04:50 AM
Thanks once again Bob for your time and advice!
Ray
