Rewire 240v to 120v
Old 11-16-06, 11:49 AM
Question Rewire 240v to 120v
I have a 240v line for an electrical stove not being used. Its a 2 pole 50amp breaker. Can I replace that breaker with a 2 pole 20 amp breaker with no link bar and use it as 2 120v lines? What is the adjusting screw in the middle?
Pictures:
http://www.geocities.com/eng99/paneldoor.jpg
http://www.geocities.com/eng99/paneluncovered.jpg
http://www.geocities.com/eng99/panelscrew.jpg
Old 11-16-06, 12:01 PM
No. This cable has no ground wire. You cannot use it for a 120 volt circuit.
Old 11-16-06, 12:19 PM
Can I remove the old wire and replacing it with 2 12-2.
Old 11-16-06, 12:37 PM
Personally, if this were my house I would get that panel replaced with a new panel.
Yes, if you can find circuit breakers you can pull this one and add a new circuit or two.
Old 11-16-06, 12:44 PM
I'm planning to, just not now, maybe in the summer.
Any ideas on wiring the ground?
Old 11-16-06, 12:51 PM
What do you mean by "ideas"? You need a ground. Connect it to the same place the other ground wires are connected.
I respectfully suggest that you buy a decent book on home wiring and read it. Start with "Wiring Simplified". You need to have basic understanding of electricity to do any electrical work.
