updating kitchen
Old 11-26-06, 11:52 AM
Red face updating kitchen
hi all, was updating kitchen wiring and found all the gfci and regular outlets are rated 15 amp, 120v. but the wiring is 12 gauge 20 amp with 20 amp breakers.(i ass u med they were all the same) do i need to change the gfci and outlets to 20 amp or is this not a bad broblem. thanks
dave
Old 11-26-06, 12:34 PM
In the US, and I assume you are from the US based on your username, 15 amp receptacles are allowed on 20 amp circuits.
Old 11-26-06, 12:40 PM
Thumbs up
this is not a problem, as stated in NEC 210.21(B)(1), 210.21(B)(2) and 210.21 (B)(3), if a 20 amp circuit serves a single recepticle, that recepticle must be rated 20 amps. If the 20 amp circuit serves more than one recepticle, the recepticles may be rated 15 or 20 amps.
Old 11-26-06, 12:43 PM
A "duplex" recept. as you now have, fits this description.
Old 11-26-06, 12:48 PM
and yes, they probably are all the same, you can easily tell without removing them. A 15 amp recepticle looks like this:
D
in other words, it has a long verticle slot, a short verticle slot, and the D shaped ground.
A 20 amp recepticle looks like this:
D
in other words, it has a long verticle slot, a slot shaped like a sideways T and the D shaped ground.
Old 11-26-06, 02:02 PM
jmchargue,
Your drawing of a 20 amp receptacle is wrong. The long slot is the neutral, and is the slot that is sideways 'T' shaped.
Old 11-26-06, 02:20 PM
ok, yes, that is correct, the other side should be the t shaped slot. my bad.
Old 11-29-06, 07:04 AM
Talking
thank you all !!!!! i never should have started the kitchen to begin with....(never give a hippe a hammer.....lol) but i am glad i did. dave
