Reload this Page >
All electricity from circuit out, but circuit not tripped - Help
Old 12-01-06, 11:05 PM
Unhappy All electricity from circuit out, but circuit not tripped - Help
I was doing some work in the basement and my wife said that many lights started to flicker. Then, everything in the house turned off and on once.
The outlet I was working on is fine, but everything that's running off of one circuit is out. It's not the one I was working on. It was not tripped and I flipped it on and off a few times, but nothing. HELP!
Old 12-02-06, 05:05 AM
The most likely cause is that a wire has become disconnected at a junction. You will have to check every location on the circuit that is partially out. The problem could be at a working location or a non-working one. Re-do all wire nut connections and check each and every connection. A two wire tester or analog meter will help you.
Another possibility is that you damaged a wire inside the wall. This will be harder to find and will mean that the wire will have to be replaced.
Another possibility is that you caused a GFCI to trip.
Old 12-02-06, 08:09 AM
william tell's Avatar
He probably broke a nuetral somewhere
Old 12-02-06, 01:40 PM
Talking Fixed
Thanks for the help. It makes sense now. The area where I was working WAS on the same circuit. There was a loose wire in there, but that outlet still worked cause it still had it's connection, just nothing thereafter.
Fortunately, that was the first place I checked. I got it back up and repaired it so that the wire will not break free any longer.
Thanks so much!
Old 12-02-06, 04:39 PM
Smile
I've used this line myself. (LOL). Sorry I couldn't help myself.
It brought back some funny stories.
