Order of assembly
Old 12-04-06, 08:54 AM
Order of assembly
Is there a preference or code as to which is installed first, insulation or wiring?I would think wiring first would be easiest. You could just slit the insulation to fit around/over the wires.
Thanks,
Dan
Old 12-04-06, 08:57 AM
The choice is yours, but usually the cables are run first. It's hard to work around the vapor barrier of the insulation.
Old 12-04-06, 09:45 AM
Additionally, since I just know your work has been permitted.... the inspector will want to see the wiring prior to the insulation work.
Old 12-04-06, 10:50 AM
In fact I did pull a permit. It's a whole house remodel in a small town, hard to hide it. Best $15 I ever spent. I think I know just enough to be dangerous, but I also know enough to get my work inspected.
Old 12-04-06, 12:00 PM
The local inspector here told me that this is the best order of rough inspections:
1. Plumbing & heating: Because waste pipes have to be installed so gravity does its job, and framing must sometimes be redone to accommodate pipes and ducts
2. Electrical: Because it must be threaded around the plumbing
3. Framing: So that all changes necessary for plumbing and electrical are inspected
Not that it always works out that way.
Old 12-04-06, 12:44 PM
That's interesting - and says a lot about different locales.... I've permitted numerous jobs in the past - and without exception it begins with framing, followed by either rough electrical or plumbing (though the three can be simultaneous) - followed by insulation/fire blocking - followed by drywall (they've counted the screws/nails and measured the spacing) - followed by final electrical/plumbing.
Glad to hear you're permitted.... and, you're right - it's the best $15 you'll spend on the project - if for nothing but peace of mind. Good for you!
Old 12-04-06, 04:34 PM
Thezster, Yep, thats the norm here aswell. Just don't think about running wires untill, the shingles,windows,doors and sheathing are in place (some areas siding). Then you get the "hurry up".
