GFI 15Amp Circuit
Old 12-05-06, 09:05 AM
GFI 15Amp Circuit
I need to find out what the NEC Code says about a GFI receptical and what the Mili Amp trip would be for a 15 amp Circuit. I had this question posed to me by someone doing an audit and I do not know what the trip point would be. I know that the manufacturer has to set a trip limit but I do not know what that trip limit is.Thanks
Old 12-05-06, 10:43 AM
ddr
ddr is offline
NEC Art. 100-I has an FPN under its definition of a GFCI that states: “Class A ground-fault circuit interrupters trip when the current to ground has a value of in the range of of 4mA to 6mA. For further information, see UL 943, Standard for Ground-Fault Circuit Interrupters.”
As for your specific GFCI, I would contact the manufacturer to see what the listed spec on that model is.
Old 12-05-06, 12:37 PM
Thanks for your help.
