Light Switch -- A little sizzle, a little smell
Old 12-05-06, 10:23 AM
Good afternoon experts! I would like to know what's the reason why on different occasions when I turn on my light switch, there's a slight sizzle sound with a slight burning smell. I could flip it on now, and it won't happen, but on occasion it will. Would you be able to explain it? And, what is the remedy?
Thank you so much!
Old 12-05-06, 10:46 AM
scott e.'s Avatar
the sizzle and smell are probalby due to an arcing condition. I assume that the sizzle/smell combination comes from the switch, and not from the fixture. I would examine the switch for loose connections. My guess is that it probably has backstabbed connections. These need to be moved to the screw terminals. Otherwise, just replace the switch with a screw terminal version, and make your conections using the screw terminals.
Old 12-05-06, 04:34 PM
Thank you for replying. Would you be willing to explain what the arcing condition is?
Old 12-05-06, 05:04 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
very simply put, a switch is simple two pieces of metal being placed against each other to make an electrical connection. What often happens is those metal pieces become corroded or damaged by an arc of electricity. When it becomes bad enough so the connection is very poor and you turn the light on, the lights will still need the same current but trying to draw it through a small area will cause that area to become heated and corroded.
It is a big circle.
anytime you open a switch that is contolling something under load, there is a small amount of arcing involved. The amount of arcing is greater as the current draw increases. That damages the contact surface which make the connection worse.
This is one reason I tend to not like cheap switches and usually use 20 amp rated switches. Since they are designed to carry more current, they tend to be even more durable when controlling less than that.
Old 12-06-06, 09:47 AM
Thumbs up
Thank you all for your great input! Happy Holidays!!
