Concrete anchor
Received 0 Votes
Concrete anchor
I'm looking for some opinions on how to best mount conduit and load centers on a poured foundation wall. I have had horrible luck with masonary bits and concrete anchors. I noticed a hex head on a screw mounting for my current panel, and I couldn't find anything like that at the home center. The ones I saw looked pretty cheap and worked in a variety of ways.
I ended up buying some that have a nylon securing bolt on the end that causes the sleve to deform. I imagine they could work well for me, but the install time will be great. I also tried some lead sleaved ones, but they only had nails to drive them in. I am considering using the lead sleave and attaching with a metal sheet screw.
So are there any preferred methods?
Received 0 Votes
Fubar411,
I just got done mounting my load center not long ago. It is on a block wall but should make no difference for a poured concrete. What I did was cut a 3/4" piece of plywood to put behind the loadcenter. I then used 2 1\2" wood screws at the top and screwed the ply into the piece of wood that runs along the top of the blocks. I then used a ramset to shoot 6 fasteners (3 down each side) equally spaced through the wood into the block. I then mounted the load center to the ply with 3/4" #12 wood screws with washers under the heads. It is solid. For conduit I just used the plastic inserts with the screws that come with them. The masonary bits work much better with a hammer drill. The hex head you saw was probably a tapcon (a concrete screw that requires no insert). Is it blue? That is another option but still requires a special masonary bit to use.
>>horrible luck with masonry bits and concrete anchors
That pretty much describes how I felt until I realized there is a huge difference between 3/16 masonry screws and 1/4" masonry screws. 1/4" Tapcons are the bomb. It seems like the 3/16 screws either don't have the threads to grab, or the masonry bit rounds out the hole too much for them to grab. I only use 1/4" tapcons now and rarely will one "spin out". If it does spin, you likely just need a longer one. And don't overtighten them. For attaching conduit, you'd probably use a 1/4 x 1 1/4" screw. Hex heads work great on standard drivers (or optional hammer setting) and phillips heads work great if using an impact driver.
A Bosch 1 1/8" rotary hammer also works better if you have a lot of holes to drill- it makes drilling into concrete seem like fun compared to smaller hammer drills- its effortless. The little 1/2" Milwaukee Magnum hammer drill we have just gathers dust now.
Received 0 Votes
Wow, some useful things here. I have a Milwaukee 1/2" hammer drill, big heavy sucker. I've already burned through one of the kits masonary bits.
Yes, I used the blue tapcon anchors. They don't seem to do well for me. The ones in my panel were silver with a philips head. I wonder if they used some sort of plastic sleave or lead. Either way, I'm probably done using these Tapcons.
But were they 3/16" tapcons? If so, I think they're junk too. That was what I was getting at... if you used 3/16" ones, try to get some 1/4" tapcons- they hold better.
It also could be that you were using a masonry bit that was slightly too big?
Good quality rotary impact bits (not cheap masonry bits for a regular drill) and a good quality hammer drill are essential. If it's poured concrete even with good quality rotary impact don't expect them to last for more then a few holes at best and always drill a smaller diameter hole first. Don't even try with a regular drill. Rent beg or borrow a hammer drill.
If using Tapcons always use Tapcon bits not just any bit. They are specially sized. Avoid philips head, too easy to strip, use hex.
as Ray posted, Tapcons use a special sized bit. If you don't use it, the holes are going to be too small (you'll break screws) or too large (they will strip out).
on this page:
http://www.concretefasteners.com/anchors-fasteners/index.htm
you will see.
several methods that will work for you. I tend to use the machine screw anchors (I have always called the hollow wall anchors becaused you can use them in block walls) but they require a special tool to install that is about $40. Not worth buying for just a few.
a friend of mine swears by the "wedge anchors" and I have used them, the sleeve anchors, drop in anchors, and single expansion anchors.
any one of them would work for you.
wedge anchors work well and I also like the sleeve anchors
on this page:
you will see.
Received 0 Votes
I've used about every type of anchor. I find the plastic sleaves to be the most versatile and forgiving ones. I've also used alot of tapcons, definately use the hex head bit. I personally don't like the tapcon drill bits, they don't last very long. I've had much better luck with the brand name bits like "blue titanium".
Received 0 Votes
Thanks for the replies everyone.
I'm mouting my Gentran transfer switch this weekend and wanted to be sure it stayed on the walls. I might try the plastic sleave ones, I thought that the lead would be better, but I'll give it a shot.
By the way, if anyone wants one, Amazon is having a crazy sale on them. They have $50 off once you cross the $300 mark AND 10% off. I was able to get my 16 circuit gentran for around $264 delivered, no tax. No reason not to hook one up at that price.
Previous Thread
Next Thread
