#12 3G NM in 3/4 conduit
Old 12-12-06, 11:32 AM
G
I've got 30 ft of 3/4 conduit with 2 #10 thhn wires inside. Do you think I could pull #12 3G Romex through it (because I've got extra) or should I just go buy some thhn? The conduit has a 90 degree bend.
Thanks to you all for all your advice and info.
Old 12-12-06, 12:48 PM
I
Received 45 Upvotes on 43 Posts
Is the conduit used as the ground?
If the conduit goes underground or outdoors, then you need to pull THWN conductors. If indoors you could do either, but I would pull individual conductors.
Old 12-12-06, 08:10 PM
L
Question
This depends on location of conduit, and the use of the ckt.
What do you need to power?
