Outside Post Light
Outside Post Light
I have an outdoor post light that used to go on at dusk and turn off at dawn. Now, it stays on all the time. Not too sure what to make of that. Thanks for any advice.
q-tip is fine for cleaning.
If cleaning doesn't help fix the problem, then I can think of at least two other possibilities:
1. The photocell is blocked by a new source of shade. Check for plants or other changes in the periphery that could be obstructing sunlight.
2. The photocell is fried, and it's time for a new cell.
I had a photo cell light that decided to stay on all the time. I cut the power to it for a 5 count and this corrected the problem. I later found out that this particular light could be set to always on by cutting power for 2 seconds and then turning it back on. Your light may work the same.
These photocells can go bad, I've replaced the one in my light 2 times, was told to not aim these directly into the sunlight this can wear them out prematurely. Mine points NNE.
