Adding an outlet beside a switch
Old 12-13-06, 04:36 AM
Can you add an outlet beside a switch in an existing home? I need an outlet beside a window. There is an light switch beside the window and I was wondering if I could take out the switch box, put in a dual switch box and add an outlet beside the switch. Thanks, Jen
Old 12-13-06, 04:39 AM
Electrically, it depends on the wiring that is in the box.
Per code it depends on the room and the circuit layout.
Start with the wires in the switch box. You need a neutral wire, in addition to the hot wire, and a ground is required. What wires are in the box, and how are they connected?
Old 12-13-06, 04:47 AM
outlet box
I am an amateur so plese tell me what I need to look for. What color is the neutral, hot, etc and how do I attach? Jen
Old 12-13-06, 04:51 AM
Old 12-13-06, 05:02 AM
Wires
How many of each color are in the box?
Old 12-13-06, 05:47 AM
Outlet
Two black and two white wires
Old 12-13-06, 06:09 AM
Are there are no ground wires? What sort of wiring is in the house? NM type wiring?
Old 12-13-06, 08:35 AM
You can provide a receptacle at this outlet-box using a single device which is a "combination" device. "one-half" on the device is a single-pole switch, and the other a single receptacle.
If the two White wires are connected together, and each of the two Black wire terminate on the existing switch, 2 White + 2 Blacks = 4 wires in the outlet-box, then one cable "pair", = 1 Black and 1 White, is a "Feed-In" cable with 120 volts between the Black/White wires of the pair when the switch is in the "Off" position.
