Bathroom wiring questions
Old 12-19-06, 05:43 PM
W
Received 1 Vote on 1 Post
#1 - Can bathroom lighting (recessed cans) be added to an existing 20 amp outlet circuit. The circuit currently servew two GFI outlets so load isn't a problem.
#2 - I want to install additional baseboard electric heating but wall space is limited. Is there a code restriction that limits how close a baseboard heater can be to a jetted tub?
Old 12-19-06, 07:33 PM
R
1. Maybe. Where are the two receptacles that are on this circuit?
2. What kind of a tub is this?
Old 12-20-06, 06:56 AM
W
The receptacles are located on either side of a vanity. I don't understand the "what kind of tub" question. It's a jetted tub that has it's own dedicated circuit.
I want to continue the 20 amp GFI circuit to provide power to the lights. I also want to install a 30", 500W baseboard heater on a separate circuit. The heater would be about a foot from the end of the tub along the same wall.
Old 12-20-06, 08:42 AM
I
Received 45 Votes on 43 Posts
As long as the existing 20A circuit supplies only one bathroom, you may add lighting to that circuit in the same bathroom.
