Cutting live black wire
Closed Thread
Old 12-23-06, 05:45 PM
For a complicated reason doing an renovation, I need to cut through a live 14/2 wire. Can't turn off power and don't want to get sidetracked as to why.
These are the two black wires connecting to a light switch. Can I wrap the handles of my plastic (maybe its rubber) coated wire cutters in electrical tape and give them a snip? Will this give them enough insulation to avoid a shock? Then I want to secure the cut ends of the wire with electrical tape.
What tool is recommended for cutting through a live wire?
thanks.
Old 12-23-06, 05:53 PM
Who are you trying to fool? There is never a reason in a residential setting to cut a live wire or to work on a circuit live. Any method of working with or altering a live circuit is dangerous.
Electricity kills people every year. Do the right thing and turn the power off.
Old 12-23-06, 06:08 PM
Even if you were stealing electricity by illegaly tapping the lugs before the meter ?
Just a guess...
Well I don't condone this activity and i am sure no one does but Poco line men do it all the time for your live service change over . As long as there is no path for current flow , your ok. So by a brand new fiberglass ladder and make sure you aint touching anything but the wire and cut it. hypothetically.
Old 12-23-06, 07:01 PM
mango man's Avatar
what trained pros with lots of saftey equipment do isn't suitable for the DIY
cut the power or don't cut the wire
Old 12-23-06, 09:17 PM
Gen
Gen is offline
I accidentally cut a live line cord once on the job. The boss saw it and much to my surprise --laughed his butt off. I don't recommend this activity though.
Why don't you explain your situation, since no one is going to inform you on this one?
Old 12-23-06, 09:31 PM
nap's Avatar
nap
nap is offline
New Member
Just a guess...
One thing you failed to notice: the OP wants to cut a 14/2 romex. it has a hot, a neutral, and a ground wire in it. Snipping that baby is going to turn a set of linesman pliers into an expensive set of wire strippers. Dumb, dumb, dumb.
If the circuit cannot be turned off, there is definately something wrong happening. In a resi situation, I can;t think of any reason an inexperienced person would ever be dealing with something that could not be turned off.
Old 12-23-06, 09:43 PM
While it might be interesting to hear an attempt at justification for this, I cannot allow something so stupid and so dangerous to continue. The answer has been clearly given, I'm going to close this post.
Closed Thread
