between 2 wiring switch to 3 wiring switch
Old 12-27-06, 04:41 PM
F
hi! i'm tryin to install new light switch...the problem is that i got probably 1940-60's light switch with two wiring white and black...but i cldnt find a new one that can accept 2 wiring...thus the new one has three screws...but i dont see a third wire for ground wiring...what should i do??
Many thanks!
Daniel
Old 12-27-06, 04:51 PM
W
Many thanks!
Daniel
You may have picked up a switch used for 2 way lighting, that is the ability to turn on a light from two different locations. That type of switch has 3 screws. The standard switch has 2 screws, one silver and one bronze and maybe a green for ground. You probably do not have a grounding conductor if your wiring is that old.
Old 12-28-06, 12:42 PM
R
All new switches have a ground terminal. If you have no ground wire in the box then connect nothing to the ground terminal. However, if the box is properly grounded then you need to pigtail from the box to the switch.
