Extending a circuit using smaller wire size
Old 12-31-06, 01:09 PM
My house uses #12 wire with 20 amp breakers. Can I add a 20 ft lighting extension (2-100w outside flood lamps) from an existing outlet box using #14 wire? Wire will be housed in PVC conduit with pvc box at the end for the light fixture.
Old 12-31-06, 01:17 PM
If you use 14 AWG, you must change the breaker to 15A.
If you use 12 AWG, you can leave the breaker at 20A.
Local codes may vary, but I am not aware of exceptions to this rule.
Old 12-31-06, 01:39 PM
Nope. Never heard of local codes overriding NEC. Adding to,Yes.
Run #12 only.
