just wondering
Old 01-02-07, 06:55 AM
Question just wondering
Do florestent light ballast use watts if the bulbs are burned out ? or is it just like an incondecent bulb, cir. it broken so zero watts used.
Old 01-02-07, 07:45 AM
No sure answer....depends. Some fixtures have the bulb in series with the ballast, some use other designs. You would have to have a wiring diagram of the ballast iteslf to know for sure. One way to tell is if the ballast feels warm with bulb bad. Some lamps have a preheat filament, so in most cases, at least that much current would continue to flow even if the arc did not strike. Again, you need a schematic for that balllast. Manufacturers like Advance Transformer and Magnetek have wiring diagrams available on their websites.
