Electrical outlet cabinet sink
Old 01-02-07, 11:37 AM
Question Electrical outlet cabinet sink
For the outlet for a disposal under the sink cabinet: Do I need armored cable? Or can I use Romex cable?
Old 01-02-07, 11:41 AM
HotxxxxxxxOKC's Avatar
It depends where you live.
Old 01-02-07, 11:45 AM
If the wiring is inside the wall then use whatever is allowed for your area.
If the wiring is exposed in the cabinet then it must be protected. This can be done with conduit, or by hiding the cable behind wood.
Old 01-02-07, 02:00 PM
You could come in high on the cabinet, then it is out of harms way. Check your local code.
Old 01-02-07, 03:13 PM
Sthrnamp's Avatar
As Bob said If you're running an outlet into the cabinet and the wire will be protected by the wall use what your local codes permit. From the disposal to the recep use a small appliance pigtail no longer than 18 inches (atleast that the code here.)
