How Many Wires?
Old 01-02-07, 01:44 PM
P
How Many Wires?
Using a fish tape and wire lube, and having access tees and els not more than 20 feet apart, can one pull four #10 wires through 1/2-inch conduit?
If not, how about three #10 and three #12 wires in the same conduit? They would of course be on different circuit breakers.
Old 01-03-07, 07:36 AM
T
Four #10 wires puts you at 28% fill in EMT, which should be fine.
Three #10 and three #12 puts you at 34% fill, which should still be ok.
Old 01-03-07, 07:47 AM
A
Remember that the sum of all bends between pull points (conduit bodies & j-boxes) cannot exceed 360 degrees by code, and the higher your fill ratio, the better off you are to limit that to the lowest number possible.
