breaker question?
Old 01-02-07, 03:30 PM
breaker question?
I have a Cutler Hammer sub panel,that i need to switch out a 15 amp breaker with a tamden 15 amp.I just ran a new 12ga dedicated line to my basement refridge.Im going with a 15 amp braker cause the other line is only 14ga.
My problem is believe it or not,I can not find a cutler hammer br1515 breaker locally.I seen them online and some of the distibutors also use number mp1515n.i have a mp1515n,which is for my murrary main panel.
Does anyone know if they are interchangable Murrary and Cutler Hammer .Matching up the breakers they look identical and will fit,but I have read here to always use the proper breaker.
Also in my CH Sub Panel,there is a few ITE breakers which were installed by an electrician.
If anyone knows if I could use the Murrary breaker I would appreciate it ,if not I will just order the Cuttler Hammer onlione and wait for the mail..
thanks
Old 01-02-07, 03:50 PM
If I remember right the correct CH part number for a double pole 15 amp breaker would be BR215. Why do you want to use a tandem (double pole) breaker for the fridge? Most fridges are 120V. Using the tandem breaker would give you 240V. Am I missing something or misunderstanding?
Old 01-02-07, 03:56 PM
jetmx,
You ARE missing something. A tandem breaker does not provide 240 volts except on some circuit breaker panels (such as GE). On most panels it provides two 120 volt breakers in a single slot.
The OP is in need of a breaker for his new circuit to his refrigerator. This is a common use for tandem breakers, providing a place for a new circuit to be connected to an other wise full panel.
lovmy4x4,
Why are you looking to replace a 15 amp breaker with a tandem? Why not replace a 20 amp breaker with a tandem 20 amp? Then you can have the full 20 amps available on the new refrigerator circuit.
Old 01-02-07, 03:58 PM
OK. Got it. Thanks for explaining racraft.
Old 01-02-07, 04:24 PM
Ra the current 15 amp breaker is only 14ga wire,so i would rather go with 15,im having hard enough time finding a 15/15 breaker,I see some 15/20 available online,but I would not even attempt looking for that locally..lol..
Plus I have an mp1515n in house ,if it could be used safely...thanks again
Old 01-02-07, 04:57 PM
Sthrnamp's Avatar
I think what Racraft was trying to ask is why not just put a tandem breaker where you already have a 20 amp breaker and run 12? so you can have ample supply...that was my question too...
