Installing new lights in 100 yr old house
Old 01-05-07, 11:20 AM
I have a bathroom which I need to put new lights and outlets in. I am working with a interior wall but the walls are 2 - 2.5 inches thick. Any suggestions on boxes to use for the outlets and the light fixtures? The new light fixtures are to mount in the wall above the mirror.
Old 01-05-07, 01:09 PM
HotxxxxxxxOKC's Avatar
What type of wiring you using?
You are creating at least one 20AMP dedicated circuit that is GFCI protected for the outlet?
Old 01-05-07, 01:15 PM
There is a near by light fixture and outlet I am going to get power from. I will be installing GFCIs. The main question is with the 'old work' boxes available they do not allow for old plaster and laft walls with sheet rock over top of them. Longer screws might work but wondered if there was a better solution I was over looking.
Old 01-05-07, 01:31 PM
They make snap-in type boxes that have clips and fasters that will hold it in the wall. Do not use a ordinary wall box, as these are to be only fastened to structural members (studs) in the walls per the NEC. (550.15(I))
Old 01-05-07, 02:54 PM
D
*Bump*
Saurd,
This thread has been moved from the Bathroom Remodeling Forum to the Electric Forum. The duplicate thread you created has been deleted.
Old 01-06-07, 05:37 PM
Saurd, these boxes are usually called "Old Work", you put them into the existing wall, and tighten a screw which pulls a plastic plate to the inside of the wall.
Old 01-06-07, 05:42 PM
R
You cannot tap an existing circuit. You must run a new circuit, 20 amps, for the bathroom.
