humming noise coming from oven???
Old 01-06-07, 07:08 AM
B
Unhappy humming noise coming from oven???
white-westinghouse 17yr old oven...when I turn on the oven there is a hum...should I be worried about this, it never did it before...there is no noise when I turn on the top burner...what can i do to check out what the problem might be?!????
thanks
Old 01-06-07, 08:51 AM
The hum, could be the prelude to a fire.
Electrical systems will make a humming noise when overloaded. I suggest that you do two things.
Manually flip the breaker for the range off then on. It may be sticking. Then post the brand of the panel. Some breakers are known for not tripping, and the humm could be an indication of a defective breaker.
Call an appliance repair man. Electricans specialize in the homes wiring. Wiring that is internal to equipment is a different speciality.
Old 01-06-07, 03:19 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
I's also suggest if you have access to an Amprobe you check the amp draw.
Old 01-07-07, 10:11 AM
B
WOW- thanks jwhite!!
I did turn the oven on again later, it made a hum noise for maybe 3 min, then it stopped...I just recently replaced both elements in it...I wonder...could there be something loose?...I will check the breaker too though...maybe its time for a new oven!!
Thanks
