Need to add a 220 volt plug for a new range
Old 01-19-07, 09:29 AM
P
Question Need to add a 220 volt plug for a new range
I currently have a stove top in my kitchen that is 15 years old and needs to be replaced. I also have a wall oven which also need to be replaced. My thought is to purchase a free standing electric range to replace both. The stove top is hard wired to an electric box under the cooktop. I would like to install a 220 volt plug, since the wire is already connected to the service panel. I'm not sure if I should purchase a 220 volt receptacle that can handle 3 or 4 prongs. When I pulled the cover off the box I did see a Brown, Red and White wire. There also was a bare copper wire that was attached to the electric box.
Thanks for any assistance...
Old 01-19-07, 09:49 AM
I
Received 43 Votes on 41 Posts
All new range installations require a 4 prong receptacle and the matching 4 wire cord on the range. Also, consult the installation manual for the range for proper installation of the 4 wire cord; you will probably have to remove a bonding strap inside the range's electrical box.
The existing wires need to be #8 AWG with a 40A breaker to support a freestanding range; #6 AWG with a 40A or 50A breaker is also acceptable. If they are only #10 AWG, then the wires are not substantial enough for a range. Examine the cable or wires for markings indicating the AWG.
When you install the receptacle, both the receptacle and box itself should be grounded with pigtails of #10 wire fastened with a wirenut to the incoming bare copper ground.
Old 01-19-07, 10:43 AM
P
Question 220 volt receptacle
I have examiner the wire leading to the cooktop and can't find any markings on the wire. Also, my current stove top is connected to a 30A breaker. it looks like I will need to replace the breaker as well. Any ideas on that one?
Thanks
Old 01-19-07, 10:45 AM
R
To be absolutely certain about the wires, you need to measure the thickness of the copper conductor.
However, being as this was a stand alone cook-top, and a not a full blown range, it is unlikely that the wires are any larger than 10 gage.
I suspect you will need to buy cable (I recommend 6 gage, even if 8 gage will do), the breaker and the receptacle.
