replacing 3way switches with dimmer switches
Old 01-22-07, 03:22 PM
Is ok to replace both 3way switches with 3way dimmer switches so the light can be dimmed from both locations?
Old 01-22-07, 04:34 PM
NO, You will only be capable of dimming from 1 location.
Think the location thru. The last setting of the dimmer will be the setting when the other switch is thrown. = 1 dimmer 1 reg. 3/way.
Old 01-24-07, 08:10 AM
Thanks
I thought as much but wasn't sure.
Old 01-24-07, 09:10 AM
Look at the Lutron Maestro line of dimmers. They make an expandable n-way dimmer kit which does exactly what you want. One dimmer is the "master" and you can have multiple remote dimmers.
Maestro multi-location dimmer:
http://www.lutron.com/maestro/?s=17000&t=17200
Maestro w/ IR remote control:
http://www.lutron.com/maestroir/default.asp?s=17000&t=17200
