Ge Panel
Old 01-27-07, 06:40 PM
Ge Panel
I bought a house w/ a 100 amp GE panel. Someone removed all the dividers on the cover so you can see in between the breakers into the panel. The breakers are not as tight as they should be. Is there something I use to "fix" this problem or do they make a replacement?
Old 01-27-07, 06:59 PM
It's called a new cover.
However, your problem may be worse than you think. Why did they remove the "dividers"? If it is because they used the wrong breakers and they needed to make them fit then you need to get the right breakers.
Old 01-27-07, 07:00 PM
They make "breaker blanks". You may have to go to an electrical supply house for them, I don't know if the box stores carry them.
Old 01-27-07, 07:10 PM
Thank you very much
I will make sure the correct breakers are in place then go to the supply store
Thank you for taking time to respond
Old 01-29-07, 10:16 AM
Yes, they do. Both HD and Lowe's have them for uncer $5 for a pack. I don't remember how many are in a "set".
