220v to 110v outlet
Received 0 Votes
220v to 110v outlet
If I have an electric rangetop and I want to install a gas rangetop I will need a 110v outlet to run the ignitors. I know I need to pull the double breaker and put in a 15 amp one. If my 220 line is 3 wire I can just cap off the red, but if it is 2 wire can I use the red as my ground? If not why?
why would you need to use the red for the ground ..even if it is three (two wire) you still have two conductors and a ground
BTW...there is no such thing as 4 wire cable (unless you are talking LV)
you only count the conductors in the cable not the ground so if you have a red/black/white and ground you have three wire..If you have only white/black and ground you have 2 wire, just trying to heko future conversations go easier
Received 0 Votes
Cap off the red, use the black and white. The ground (bare) goes without saying. It will be very hard however to get that #6 (or 8) into a 15A recep.
If you can, I would suggest a new run of #12/2 NMB. and just abandon the range cable.
"You could use any color wire as the ground as long as you wrap green phasing tape along its entire exposed length."
Not true.
You cannot re-mark anything smaller than #4 to use as a ground.
#6 and smaller MUST be green or bare along it's entire length.
Not true.
