wiring for an over the range microwave
I plan on running a dedicated 20 amp circuit for an over the range microwave during my kitchen remodel. My question is, are most models plug in or direct wired into a box. Also if plug in, not sure at what height to mount the receptical, or do most people mount it inside the cabinet above and feed the wire up into it. Thanks in advance for your help.
Most over the range microwaves are plug in (probably in case they go bad) and yes the plugs are mostly installed inside the cabinet...merely cut into the backing of the cabinet to expose the box and then install the recep through the cabinet backing (be sure to use a BE1 (item number) to protect against the wood going up in flames (code issue)
Yes, your spot on.
Mount the rec. in the cabinet.When you mount the MW the cord will go into the cabinet.
This will also meet code.
thats the "technical" name for it It is a plastic aggravation that inspectors like to see on plugs that are surrounded by wood. The BE stands for "box extender" you should be able to find them at your local HD
However if this is a "new" old work box, you don't need the extender.
I think what sthrnamp is suggesting, is if this were an existing box and new cabinets were installed. Then you would need an extension. The added old work box will sit flush to the cabinet and be code compliant.
