Moving a 220v Outlet
Old 01-29-07, 08:36 PM
mikey's Avatar
Question Moving a 220v Outlet
I am in the process of remodeling my kitchen. My 220v outlet for my stove needs to be moved over approximately 18 inches. I am wondering if this is something I can attempt myself? I understand that the existing outlet box will be the junction box and it must be and will be accessible from within a cupboard unit.
I just finished rewiring the 110v switches and plugs that I needed to move, so I am familiar with electrical wiring but I have never tackled a 220v circuit extension.
Help!
Thanks in advance.
Old 01-29-07, 08:40 PM
Does this circuit have four wires (red, black, white and ground) or three wires? If three wires, what colors?
Maybe the old wiring will reach to the new location if the wires are rerouted. Can you do this?
Will you be reinstalling the old range, or a new range? Does the range have both 240-volt and 120-volt components, or is it purely 240 volts? Note that ranges with clocks or lights are usually 240/120.
What is the size of the breaker (i.e., the number on the handle)?
In what year was the kitchen built?
Old 01-29-07, 08:42 PM
nap's Avatar
nap
nap is offline
New Member
if it is a 4 wire 240 circuit, yes you can.
If it is only a 3 wire 240 circuit, no you cannot. It must be upgraded to a 4 wire circuit is altered.
Old 01-29-07, 08:51 PM
mikey's Avatar
Question Moving 220v Outlet
Unfortunately the wire is not long enough to reach. Seems the electrician barely put enough wire to make it to the outlet. I will be reinstalling the old stove. The house was built in 1978.
It is a 4 wire (red, black, white & ground).
The breakers are 2 ganged 40 amp breakers.
Mikey
Old 01-29-07, 09:09 PM
nap's Avatar
nap
nap is offline
New Member
Yes, you can extend this curcuit as you had descibed earlier.
Old 01-30-07, 06:12 AM
jn
jn is offline
Mikey,
Get a couple feet of #8 AWG (4 wire), a new work box, and some large wirenuts that can handle splicing the 8 AWG wire, and a blank plate for the old box.
Put your new box where you want it, fish the new wire between the old and new box.
Wire nut the new wire to the old wire matching up the colors.
Leave the old box accessable but cover it.
If you just moved other 110V wiring, I don't think this would be too much of a stretch for you.
I'm sure others will add in comments for anything I missed...but this seems relatively straight forward.
Old 01-30-07, 06:24 AM
Get more than "a couple of feet." You need six inches in each box (that's one foot) and then whatever distance between the boxes, taking into account the necessary turn radius, if applicable.
Old 01-30-07, 08:51 AM
mikey's Avatar
Smile
Thanks all very much. I am on my way to get the parts I need and will let you know how it turns out.
Mike
