COAX cable with 12o v romex ?
Old 02-14-07, 06:25 AM
Smile COAX cable with 120v romex ?
Can I run COAX and phone line jack in a 3 gang box with a 120v recepticle ?
Old 02-14-07, 06:58 AM
No, not unless you get a box with a separator panel between the sides.
Old 02-14-07, 07:01 AM
Speedy Petey's Avatar
They sell 2-gang covers with low voltage on one side and a receptacle cover on the other.
But to answer your question directly, no. As Racraft said, you cannot have them in the same box without separation.
Old 02-14-07, 10:01 AM
hornetd's Avatar
It's possible.
If you want the devices all in the same box you will have to buy a multi gang box that takes a three gang plaster or tile ring. The ring will have slots in it to hold a divider plate in place. The divider plate will be between the power receptacle outlet and the two communications outlets. Such boxes and covers will be available at an electrical supply store. I doubt that you'll find them at a box store.
Tom Horne
Old 02-14-07, 10:16 AM
mango man's Avatar
they cant share a conduit getting to the box ,
Old 02-14-07, 11:20 AM
Who said anything about conduit?
Old 02-14-07, 12:30 PM
Even if you get the divided box, and thus make it legal, it still may not be a good idea if you care much about EM interference.
Old 02-14-07, 01:06 PM
jn
jn is offline
Kevin,
Just my humble opinion, but I think you will probably be happier in the end if you keep your COAX and phone line at least 12" away from your 120V. Any closer and you may start to have noise problems on the low voltage lines.
