New receptacle in plaster wall
Old 02-14-07, 11:21 AM
This may not be the right place to post this but ... I need to add a receptacle in a plater wall. Any suggstions on how to cut the hole for the box without distroying the plaster wall?
Old 02-14-07, 11:36 AM
Plaster Wall
Put your box on the wall where it is to go. Mark a line around it, score the mark with a razor knift a few times. Drill a hole in the four corners large enough to get a key hole saw into it. Just cut alonge the line.
It's best to find the 2x4 wall stud in the wall before you start and cut the hole beside the stud so you can connect the box to it. You can also use the outlet boxes that have flap holders and will hold without a stud as you turn the screws tight.
Where are you going to connect the wiring to for the new box, is there power lines inside the wall?
[email address removed]
Last edited by racraft; 02-14-07 at 11:41 AM. Reason: email addresses not allowed in posts
Old 02-14-07, 11:42 AM
If the wall is true plaster and lath - you can plan on throwing away the keyhold saw once you're done... that plaster will eat the blade quickly. I personally prefer a sabre saw with cheap disposable blades. Use a "remodel" box - the ones with the wings that spread to attach to the interior of the wall - though, depending on the thickness of the wall, you may have to find longer screws than the stock ones to work properly. Cut your hole, ensure the box fits - run your wiring through the wall and into the box - then install the box into the wall.
Old 02-14-07, 12:11 PM
Many people find that a rotary saw (like a Rotozip) is better for this because it doesn't cause so much vibration to the wall that may shake some plaster loose.
Old 02-14-07, 12:58 PM
yes this will work very well as John Nelson speaking and only one catch is it will kick up a bit of dust but when you get it done it look very neat and when you mount the box make sure you have lath strip to support the box most of the time you will see it if you are very carefull with it
Merci , Marc
