heater blowing main breaker
Old 02-14-07, 01:16 PM
L
Cool heater blowing main breaker
I just wanted to see if someone out there could help me out. I have a problem with my heater blowing out my main circuit breaker after its running for about thirty minutes. I have a double 125 amp GE main circuit breaker. When I go out to reset it, I have to wait a couple of minutes because it continues to trip and it is hot. I havent't checked any of the wiring yet just wanted to see if anyone had any knowledge of what may be some good steps to take first. Thanks
Old 02-14-07, 01:27 PM
Speedy Petey's Avatar
From the description you give it sounds like you have a serious problem with the main breaker, not the heater. Especially seeing that the breaker is hot and not able to re-set.
I would strongly recommend having a pro evaluate this situation. This is NOT anything for a DIYer to mess with, unless you are QUITE advanced and have a really good clue about what you are doing.
Old 02-17-07, 06:38 PM
L
Not a good situation.
IFOLEY: Post back with your findings.
I'm sure your not the only one with this problem.
