Timer for Bathroom Fan?
I was hoping I could get some options on and idea I am considering. We will be replacing a bathroom exhaust fan with a new (stronger cfm) one in the next few weeks. Currently the one that is installed is operated by a simple light switch. I have heard suggestions that installing a digital timer would be a good idea. This would allow the fan to run for a defined period following the shower to exhaust out more of the humid and moisture air.
Is it really a good idea to have a digital timer in a moist area like this? The manufacturer (TORK) information does state it can be used in bathrooms.
Would an electromechanical timer be a better idea or would it be best to stay with the simple light switch that's currently there?
I have no made any decisions yet but would be very interested in any comments or suggestions people have.
Thanks for your time and thoughts.
Make sure that whatever you get, it is rated to control a motor. Don't get one designed to control lighting.
I'd vote for the simple "turn past" mechanical timer. Most of the electronic timers need a neutral and/or a battery. The mechanical timers are much simpler.
I do not know the manufacturer but a switch that is just what you are looking for is on the market. I didn't install it but another guy from our company. It is in a "Talbot's" womens clothing store.
It is 1 switch with a with a delay off timer built into it. It allows one switch to operate the lights and the fan but when the light is turned off, the fan continues to run for a predesignated time.
My electrician installed a Leviton digital timer. Its really nice and works great in bathrooms. It has 4 presets, you can get
5 min, 10 min, 20 min, 30 min
or
10 min, 20 min, 30 min, 60 min
They do need a neutral connected to it to work. They are beautiful and very elegant.
or
Here is what it looks like:
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?a=b&item=8809
Here is a site to get some info on it:
http://www.smarthome.com/4254w.html
I do not endorse smart home, never bought from them, just listed their site as they provide complete information on the product.
This one was recommended to me by an energy auditor. I like the idea that you set the time once, under the wall plate, and it is then just a simple wall switch. I've already found that a mechanical timer and multiple timer buttons are viewed quite dimly by certain others in my home:
http://www.energyfederation.org/consumer/default.php/cPath/39_766_134
