Joining two feeds of 220?
Old 02-17-07, 05:12 PM
In the kitchen of a house we are flipping are two 220 feeds, one for the RANGE top, and one for the BUILT IN OVEN. Both are hooked to separate 30 amp breakers. The lines are copper 10 ga. This house was built in 1968.
We have removed the two units in favor of a free standing RANGE-OVEN combination. The installation instructions call for 40 amp service, and I wonder if I can somehow combine the two 30's into one 40 or 50 breaker.
I welcome any and all comments.
Thank You for hearing me out.
Dale
Indy
Old 02-17-07, 05:17 PM
ray2047's Avatar
No. You must run a new 4 wire circuit #8 minimum but # 6 would be better in case there are future changes iin range used..
Old 02-17-07, 05:25 PM
No you cannot do this. It is wrong on many counts. Run a proper circuit for this device.
Old 02-17-07, 05:26 PM
Talking
You sound tempted.
So I will support. NO don't even think of it.
You can rip out the 10/3 and junk it, you may re coupe some of the cost.If that helps.
Old 02-17-07, 05:27 PM
Agreed, I would run a 4-wire #6 feed and protect with a 50A breaker. This will work for your currently intended appliance as well as most modern replacements.
You have to run a new feed anyway.
Old 02-17-07, 05:52 PM
Smile
Wow, now that's what I call a resounding NO.
I would have been TEMPTED had the vote came in 3 YES, 1 NO.
Thanks to all,
Dale
Indy, the corn field with a race track in the middle, and NOW THE WORLD CHAMPION FOOTBALL TEAM, go Colts.
Old 02-17-07, 06:07 PM
Wink
Dale
I'll sell ya Coldwell!!!! Congrats!
Old 02-18-07, 07:08 PM
I don't think you'd ever need to use 6 gauge wire for a residential range...
you can use a 40a or 50a breaker
Old 02-19-07, 04:18 AM
Speedy Petey's Avatar
For a 50 amp circuit wired with NM cable #6 IS required.
ANY household cooking appliance rated 12kw and less can be used on a 40 amp circuit.
