generator hooked into house power supply
Old 02-19-07, 05:20 AM
In case of a power failure someone told me that as long as the Master Breaker was turned off I could hook up the generator into any wall plug with an extension cord and there would be power throughout the house.. Can someone confirm this idea..TIA.
Old 02-19-07, 05:41 AM
No. This idea is:
1) illegal.
2) stupid.
3) a good way to kill someone.
4) a good way to burn your house down.
The only way to connect your generator into your house electrical system is to use a properly installed generator transfer switch or a properly installed main breaker interlock kit.
Old 02-19-07, 06:30 AM
AxlMyk's Avatar
It will only work for circuits plugged into 1/2 of the breaker box, and could overload the line you plug into..
Do it right and use a 220 volt connection.. Another suggested method was to use extention cords, but I don't see the point in laying out trip wires around a dark home..
Old 02-19-07, 06:33 AM
Exclamation
Originally Posted by racraft View Post
No. This idea is:
1) illegal.
2) stupid.
IT IS WORTH REPEATING!!!!!
Listen to the advice.
Old 02-19-07, 07:17 AM
In addition to the four deadly flaws already mentioned, it won't work anyway.
Old 02-19-07, 09:56 AM
i dont know who told you about this
this is freaking insane to do this and i will not repeat what other say above me
this is illegal way to do this
and for sure you will tick off the POCO if they found out if backfeeding it get pretty ugly there [ i will not tell you the details but i did see it myself ]
merci , marc
