Siemens Double Pole AFCI?
Old 02-19-07, 07:29 AM
New Member
I have a 14/3 running to a bedroom. Need AFCI protection on both circuits (using shared neutral). I haven't been able to locate Sieman's/Murray double pole AFCI breakers at any of the supply houses. 2 questions:
1. Is a double pole breaker the only way to wire an AFCI shared neutral?
2. Does anyone know of a supplier that carries 2 pole AFCI's?
Thanks!
Old 02-19-07, 07:35 AM
1. Yes.
2. I do not.
Old 02-19-07, 08:05 AM
New Member
Supplier needed
Thanks for the update - I'll keep watching to see if anyone knows how to locate the breaker . . .
Old 02-19-07, 09:43 AM
Speedy Petey's Avatar
A Cutler-Hammer BR215 AFCI breaker will fit. I am not sure if they are classified to be used in a Siemens panel though.
Old 02-19-07, 09:51 AM
SpeedyPete :
I did double check with my catalog book and yes the BR215 AFCI will fit the semins box but it is not classifed at all due the ul requirement but i dont know if the inspector will allow it but i doubt at all.
unforetally i dont have semins catalog book with me as i am speaking if i do i will run that number quick
Merci , Marc
Old 02-19-07, 10:23 AM
Siemens does not make a 2-pole AFCI breaker. Are the load demands on the circuit low enough for you to combine the hots into one 120V circuit instead of a multi-wire circuit? You could then use a 1-pole AFCI breaker, but would have only [email protected] available instead of [email protected]
Old 02-19-07, 10:30 AM
New Member
Can't combine into one circuit
I have the following load on both circuits:
12 receptacles
1 ceiling fan
5 light fixtures
Seems like too much to put on one circuit.
So only one breaker will fit, but it's not listed for that purpose.
Any other ideas?
Thanks.
Old 02-19-07, 11:26 AM
What areas do those 12 receptacles serve and what are the wattages of the light fixtures?
