Furnace generator switch
Old 02-20-07, 11:31 AM
I bought a furnace generator switch and i am in need of help on how to wire it to my furnace. It is a reliant generator to furnace switch. Im just not sure on how to wire it inline with the furnace.... any help would be great thanks
Mark
Old 02-20-07, 12:16 PM
Not sure what a 'furnace generator switch' is. Can you post a link?
Old 02-20-07, 01:07 PM
Does it come with instructions? Do you have a specific question about the installation?
Old 02-20-07, 02:04 PM
http://www.amazon.com/Reliance-Controls-TF151W-Furnace-Transfer/dp/B000HRWG8U/sr=8-1/qid=1172008716/ref=sr_1_1/103-6359466-4560600?ie=UTF8&s=hi
Reliance Controls TF151W Furnace Transfer switch
Here is the link. Im just not sure on how to wire it to the frunace. Its got a ground, neutral, Black, red wires. do i wire it like you wire a switch. just not sure
Old 02-20-07, 02:15 PM
Follow the directions that came with it. I could make a guess, but will not in case I am wrong.
Old 02-20-07, 03:06 PM
just follow the direction very carefully with this one
if you have any doubt just get ahold of electrician they can do this really fast as well
Old 02-20-07, 06:21 PM
TRy this at your own risk.
I'll go out on the limb.
REMEMBER that the panel has live electrical parts in it. And if you touch the wrong parts you could be hurt or KILLED! proceed at your own risk.
1- Identify your furnace/ heating ckt.
2- mount your new box securley.Next to your electric panel.
3- connect the flex- looks like 1/2-3/4" to the existing elec panel. Use the apropriate size knock out hole for the new flex.
4- connect the white wire from new trans fer panel to the neutral bar in house panel- (white wires).
If the grounds (bare wire) are connected to the same buss then connect the new GREEN wire there as well. If not connect the green to where the other bare wires are.. "GROUND BAR".
5- shut off the breaker for the heat.
6- remove wire from the breaker.
7-splice wire from breaker to black wire in the transfer panel.useing a wire nut.
8- place red wire from transfer panel to the ckt breaker,and tighten.
Replace cover on electric panel and turn on heating ckt breaker.
You should be done now.
Last edited by lectriclee; 02-20-07 at 06:23 PM. Reason: Add: next to your electric panel
