Homeline panel board
Old 02-21-07, 06:50 PM
new 200 amp panel board (42 circuit) does not have sufficient openings for ground and neutral connections. I have approx. 33 circuits in the box. Can I place more than one 12 gauge wire in each hole or must I add an additional ground bar on each side of the panel board. thanks.
Old 02-22-07, 03:36 AM
Speedy Petey's Avatar
You can double and even triple up on like sized grounds.
Neutrals MUST be one to a hole.
Old 02-22-07, 04:44 AM
You can also add additional ground bars as needed.
Old 02-22-07, 06:38 AM
A grounding bar kit is only about $5 and available at home centers.
