circuit tracer
Old 02-25-07, 07:54 AM
scott e.'s Avatar
circuit tracer
We just purchased a new building for my business. We have a couple of 240 heaters and outlets that are not working and I need to find what breaker controls them. I have looked at wire tracers, but it seems that most ~$100 units can only trace live circuits. I would like to find one that can trace dead circuits but not spend $500. Any suggestions?
Old 02-25-07, 08:15 AM
Look carefully, most tracers you can use on dead ckts with the aid of a battery for the signal power.
Most good ones are around $150-300.
Old 02-25-07, 09:36 AM
nap's Avatar
nap
nap is offline
New Member
or you can simply do what many of us do in such a situation:
start opening junction boxes and wiggle the wires while another watches in the next j-box. Continue this until you get back to the panel that serves those appliances.
depending upon how large of a building or how it is constructed, it can be fairly simple and easy or arduous and time consuming.
This often results in finding the reason for the dead circuit as well.
Old 02-25-07, 10:18 AM
I would not use a tester that is designed for dead circuits in this case.
You may get lucky and find the fault, and at the same time ruin an expensive tool.
Old 02-25-07, 10:21 AM
Since a circuit map of your facility is a handy tool to have anyway. Why not take this opertunity to turn off all the breakers.
Then turn them on one at a time and map what breakers control what recepticles or loads.
The breakers that seem to do nothing will likely be the breakers that you wanted to find in the first place.
Old 02-25-07, 10:54 AM
This is true. I was thinking on the lines of checking the neutral, But this is 240V. So the main power should be cut before testing this way.
Well guess your left with the old fashioned way. (hard work).
