3 phase panel
Old 02-28-07, 09:27 PM
3 phase panel
I am looking for info on how to calculate for load on a 3 phase panel
I.E ........100 amp. 120/208 panel and i have (Some # Watts). Do i simply divide the Watts by volts(208) to see if this size panel will be appropriate. Or am i missing something.
cheers
Old 02-28-07, 09:41 PM
to make load caluation on 3 phase panel and 3 phase system are little more trickier than single phase system.
i will give you a quick example
for line to netural load [ single phase ]
watts / volts = amp
line to line [single phase ]
watts / volts = amp
line to line [ 3 phase ]
watts / volts / 1.73 = amps
but becarefull with figureing with 3 phase load it little more compated but if you can give me some figures i will get the correct answer there
Merci , Marc
if the figures are wrong let me know at the same time i will double check my chart as well to make sure i get it right
Old 02-28-07, 10:13 PM
updated info
my figures came out right just let you know that the " / " is divison
but want to head up being a 3 phase system genrally used in commercal area but very rare it do have in home [ super large home ]
so the way to load demand figures are more trickier and there are some code issuse will show up on this one as well
Merci , Marc
Old 02-28-07, 10:34 PM
The panel is in a workshop....120/208 ...100 amp. Load requirements are as follows
Basic 6272.5w
equipment 14000 w these are all single phase motors varying from 1-3 hp
heat 16000w 100% 1st 10k... 75% remainder considering this commercial/ industrial workspace
Total load 36272.5
Appreciate your help...Show your work so I see how it unfolds
cheers
Old 02-28-07, 11:17 PM
ok but you did not mention the electric heating device is on single phase or three phase because it will affect the figures
and what i useally do is list the indiduval motors first [ how many motors and how many will be running the same time ]
second the lighing load and others as well senice you listed basic stuff at 6272.5 W
that need to break down some more so i can do the load demand figures better this way
if this heater wired for true 3 phase
16KW = 44.41 amps [ 3 phase but if wired on single phase it will run at 77 amps ]
i always figure the heating or A/C which ever is larger and use that nameplate rating
lighting load genrally useally 3 watt per sq foot [ but this can change depending on what conferation it will be ]
other genral loads have to be listed as well
but back to the point here how many sq feet the building you have ?
and if you have office space i will count that sq footate as well and main area in commercal /wharehouseing area as well
i cant give you the drict answer but you mention 100 a 3 phase service in fact my option it is too small you need 200 amp service anyway
let me know the other figures
merci , Marc
