Daisy chaining door chimes?
Old 03-01-07, 10:51 AM
Hi all, I have a door chime on the main floor, but I can't hear it from my basement, so I went and bought another chime. My question is, can I safely (and within code requirements) daisy chain this second one from the original chime? I'm assuming I would be able to double up the wires of each terminal and send the other end of the wire to the new chime.
And I don't want to go wireless and change out my whole door chime because it is working perfectly on the main floor.
Old 03-01-07, 10:58 AM
Yes, you can daisy-chain them. You will likely need to switch your 10va transformer to a 20va or 30va transformer.
Old 03-01-07, 11:06 AM
Thanks for the quick reply John.
Not sure what the old transformer is, but the one that came with my new one is a 16V. How can I find out which transformer is sufficient enough for 2 door chimes?
Old 03-01-07, 11:08 AM
Try it using the existing transformer. If it doesn't work then you need a larger one.
Old 03-01-07, 01:20 PM
Look at the rest of the writing on the transformer. In addition to saying 16V, it should have some other information on it.
