Question on Duplex Breakers
Old 03-02-07, 12:56 PM
Question on Duplex Breakers; I was considering using a QT Type Duplex Breaker on my Breaker box. I currently only have singles and the actual box does not state the QT type unit. Iíve worked with an Electrical that used these in my fathers house but Iíve lost touch with him.
Any suggestions would be greatly appreciated. I attached a Link to the (2) Pole Duplex breaker Iíve refereed to. Thanks Tom
http://www.sea.siemens.com/resident/product/SQT98.pdf
Old 03-02-07, 02:11 PM
Received 42 Votes on 40 Posts
What is the make and model number of the breaker panel you have?
Old 03-02-07, 02:22 PM
I'll have to check the Model Number and repost; Its a Siemens Panel. Stay tuned. Thanks
Old 03-02-07, 05:20 PM
The Panel is a Siemens and there are (4) model numbers inside:
Catalog #: G2020B1100
Catalog #: G2020B1100 # CU
Catalog #: G2020B1125
Catalog #: G2020B1125 # CU
Type 1 5419502
It has (20) Slots; if there is any other information you need let me know.
Thasnks ibpooks
Old 03-02-07, 06:56 PM
The "2020" tells you that this panel does not accept any tandem (aka twin, aka skinny, aka duplex) breakers. 20 spaces, 20 circuits.
Old 03-02-07, 10:35 PM
Darn; I'm running out of space! So if I have (6) reccessed lights and about 6 plugs on one and the laundry room on a second; would I be OK? Not major on the circuts just a computer and fish tank.
Thanks for your help!
Old 03-03-07, 09:50 PM
As long as you're careful about what you plug into those receptacles, you should be fine. No space heaters, no hair dryers, no vacuum cleaners, no laser printers, etc.
Old 03-05-07, 11:52 AM
Thanks again John; I returned the Dual Switches and will be installing (3) 20AMP Singles. Now I have to deceide how to work with Panel (another Thread you are helping me with)
Thanks again; I'f you're ever in the Detroit area (Subs about 45 minutes from the city) let me know because I owe you a beer! Tom
