Fish Tapes
Old 03-05-07, 06:53 PM
michaelshortt's Avatar
Fish Tapes
I am trying to run a horizontal run about 15 ft between floors. Lots of stuff in the way. I am using a 20 ft Gardner Bender fish (1/4 inch) and am wondering if maybe I should rent another if some are stiffer than others or is it time to cut the ceiling sheet rock at the half way point.
Old 03-05-07, 07:11 PM
Ed Imeduc's Avatar
Wink
Who know what you will run into. Id cut the drywall out. Not hard to patch it
Old 03-05-07, 07:34 PM
Thanks Ed, another hole it is, might try a couple time more and than make a cut. I am getting very good at taping.
Old 03-05-07, 08:06 PM
Sthrnamp's Avatar
there is a product out there called glo sticks...atleast thats what we call them...they are 6' long pieces of stiff fiberglass that has a luminescent propoerties so it glows when you fish it down the walls or theough floors so you can see what you're doing...(I don't likw cutting sheetrock if i don't have too) Just FWIW...good luck
Old 03-05-07, 08:17 PM
Is the ceiling strapped? if not, cut holes. If yes, make a tight hook on the snake, tape it. Then make a slight "offset" in it. Push gentley,when it stops, give the snake a "flip", then push some more.
This is an art, and takes time to perfect. Even then..... You must brush up on some bad words, and mummble them under your breath. (This helps me).
