Block Transformer polarity
Old 03-08-07, 10:03 AM
Hi All,
I have a 5V. block type transformer hardwired into a charger for a tool. The transformer is bad and I need to replace it. However, since the transformer no longer works, I cannot determine the polarity of the two wires. One is solid black and the other has a stripe running through it.
Can anyone help me to determine if the solid is + or -. There must be a convention for wiring transformers.
Thanks!
Len
Old 03-08-07, 10:06 AM
Generally speaking, the striped wire is the ground or neutral, depending on whether the transformer is DC or AC.
Old 03-08-07, 10:12 AM
5V transformer polarity
Thanks, Bob.
The transformer plugs into AC and outputs 5v DC to the tool charger.
So, from your reply, I am assuming the solid wire is +.
Is my assumption correct?
Thank you for taking the time to address my problem.
Len
Old 03-08-07, 10:15 AM
Open up the charger and look which wire was connected to the positive battery terminal. That would be the positive wire.
Old 03-08-07, 12:28 PM
5V. Brick transformer AC to DC
Thanks, again, Bob for your response.
I'll check that tomorrow and let the forum know the results.
Len
Old 03-10-07, 01:58 AM
A DC transformer? Are you serious?
Old 03-10-07, 07:12 AM
He is refering to one of those things I call wall warts. They come in DC or AC output.
Old 03-13-07, 09:47 AM
Typically the stripe goes to the center terminal of the plug.
There should be a diagram on the adapter otr the tool with the polarity.
